1 2 3 4
5
Submeg 00:38 1st March 2007
Whoa thats cool, but a bit expensive for me at the moment. I will probably get two 500 GB disks.
[Reply]
wilsonsamm 00:34 24th July 2007
and only thirty years ago people were still weaving core memory by hand. And 16 bits of memory would cost you the modern equivalent of £1.
[Reply]
Harrison 01:12 25th July 2007
Punch cards were great, well until you needed to edit the data...
[Reply]
Demon Cleaner 05:03 25th July 2007
Or the program got a return code and you had to restart with the program. We also had that here at work, long time ago. You had boxes with programs on cards, and feeded them to the machine.
Also annoying was, when you dropped the box, and had to sort out the cards again in the right order
[Reply]
v85rawdeal 09:02 25th July 2007
or worse...
One went missing!!!
[Reply]
Demon Cleaner 09:48 25th July 2007
Originally Posted by :
or worse...
One went missing!!!
Then you simply rewrite the small missing code and print/punch another one
[Reply]
Harrison 13:50 25th July 2007
You still actually used punch cards until recently?
Sounds like the admin of that system was holding out for one hell of a service pack for the latest OS before taking the plung and upgrading!
[Reply]
Demon Cleaner 14:05 25th July 2007
No, of course not. But I still saw the punching machines, as we still have one as showcase in the entry of our administration.
But I'm already working there for almost 12 years now, and the older ones told me how they had to run their jobs.
And of course I also wrote programs in JCL where you have a program that you can call during your own (programs made by IBM), and we had one to print/punch (called
IEBPTPCH).
WE used it to print, which is the same procedure when you use it to punch like in the past.
[Reply]
Harrison 14:14 25th July 2007
I see. Much like any long running OS, it has it's querky commands due to legacy commands still being used and adapted for modern purposes.
[Reply]
1 2 3 4
5
