[QUOTE=Harrison;49430]Originally Posted by :
One thing. You mention you are using a 120Hz 3D LCD. Did you know that these still operate at 60Hz? They need the 120Hz so they can deliver 60Hz to each eye (splitting the 120fps into left and right 60fps halves).
Correct, but only when running in 3D, which I don't & have no interest to do so & nor do I want to bombard each eye with a nasty flickering 60Hz.
As you seem to be focused mostly on just FPS then if you think your setup gives you the best results than fair enough. I don't play FPS that much. I'm mostly into RPG and Strategy games more and for those the extra screen real estate is very much needed. Everyone has a very different set of needs when it comes to the hardware and software we use. First and foremost I need a display that is capable of delivery as high a colour Gamut as possible for image and video editing, and more Dell is one of the best on the market for this (even comes factory calibrated). And for me 60Hz is fine for gaming, even FPS. I honestly don't notice any issues. You might and therefore using this monitor might not be for you, but for me it is perfect.
If it's screen real Estate you want with high FPS and VSYNC enabled, then you'd run dual or even 3 screens with 120Hz Monitors, but not a dell with 60Hz @ what-ever it's native resolution might be.
I would partially agree with you with Regard to video eding & hight Gamuts, but more so for picture editing or book publishing. The latter of course better supported with Mac's.
If you honestly can't appreciate the difference between 60Hz & 120Hz or greater for a more satisfying gaming experience, then there is nothing I can do to convince you. I've seen people @ huge professionaly organised Lan partys with all the kit to participate in the best possible way, but only running @ 60Hz. After fixing their refresh rates, I never had one person say they couldn't see or feel any difference & 85% of those I did fix didn't even know how to set up their refresh rates correctly or realise that VSYNC makes a massive difference to how their game experince potrays itself. I believe there are now LCD's claiming to do 144Hz, which should throw 72Hz into each eye, therefore helping alleviate damage to the eye with only 60Hz. I can't beleive the industry got away with that one, much like the shocking Sony bastardisation of BluRay @ 24FPS. :rolleyes:
