QNAP TurboNAS TS-659 Pro II
I set it up yesterday, with 6 Hitachi Deskstar 5k3000 2TB disks, and set it to Raid 5 mode. This was done very fast, I was quite surprised, the NAS did the whole Raid 5 configuration in about 10 minutes.
I also started copying my stuff to it, still will need longer time until everything is copied, but so far I'm happy with the transfer rate, which stays constantly at 70MB/s. Only copying from my main disk was a bit painful, as that one is always spinning because torrents are up/downloading, and so I only got 10MB/s.
You can find all of the information about the QNAP TurboNAS TS-659 Pro II here.
http://i5.photobucket.com/albums/y18...-Pro-II_02.jpg
Buffalo Link Station Pro Quad vs. QNap TS 659 Pro II
I dont know how your experience was with buffalo, but mine was terrible. 2 weeks after I had my unit it failed with an E07 logic board failure, we did the rma dealy got the mind you refurbished replacement unit, keeping in mind my unit was less than 2 weeks old, I felt short changed, but let it go. 2 months later same error E07 Logic Board Failure, once again did the RMA thingy mind you both RMA's were Advanced to be sure I did not get my same unit back. It has been running now for 3 months with no errors so far. Other than the unit being faulty oob, it was a nice unit, if you had lots and lots of free time to put up with the slooooww transfer speeds. So I began digging and found Synology and Qnap as 2 of a possibility of 3 or 4 others I wont even mention the names, I know from past experience with those companies they are junk oob. With all that heartburn and work, I found someone that offered me $400.00 Cash for the Buffalo I even tossed in my totally legal collection of software, movies and music
I just wanted to be done with it. Although with the sale of that came the agreement of me coming to his house to install the unit. I would rather do that than have the customer attempt it and jack everything all up.
So now that the saga of the failing Buffalo is over with, I just purchased the Qnap TS659 Pro II with 5 x 2TB Deskstar drives installed.
The question I have for you since you seem to have the same drives and I do believe the same unit, did you notice a big performance data transfer rates and what not. I do have Verizon Fiber Optic service with 50/50 synchronous bandwidth along with a dynamic IP.
With the Buffalo I was averaging 25 - 40 Mbs at best on the transfer rate up or down. Does it seem like the Qnap out performs the Buffalo. I so much wanted to have the Constellation drives installed but but got stuck short on cash so I had to go with the Hitachi Deskstar Consumer drives.
Also another question for you, I currently have all of the data that will eventually be installed onto the nas in the form of One File Rar's, the unit I have this data sitting on is a Startech 4 Bay Raid Box that plugs into my eSata controller. Can I direct connect the Startech to the Qnap and do a direct data transfer to the device? Or do I need to do it over the Network, as was with the Buffalo.
The only reason the Startech is in the picture is to be able to have space to archive up all the data into oone file rar's then transfer them to the Qnap. This way anyone downloading for one can just download 1 file, and for 2 if Qnap is anything like buffalo it will make any multi file folder into a zip called download.zip which I found proved too unreliable.
Thank You for listening and putting up with my bitching and whining, I do have plenty of cheese and a bottle of real wine. hehe haha just had too toss in a bit of humor to lighten the load.
Thank You in advance for anything you can do....
Regards
Rob
